Unable to retrieve TypeId from DocuRef table for SSRS report
Good day.
My client needs a new report and for the report I have to check customer and vendor attachments. When I test the table selection in a job, the DocuRef.TypeId has a value, but when I print the report the field is empty. The report has no special design, it is just a simple table. I need the TypeId for the if statement, but it looks as it never fetches the value. I created a table "testTable" for testing to see what values are fetched and after I execute the report I see that TypeId is empty in all rows but the table DocuRef itself has no row with an empty TypeId field. I am doing something wrong but I just can't see the error. I hope you could help me. Code below. X++: public void processReport() { CustTable custTable; VendTable vendTable; DocuRef docuRef; LogisticsPostalAddress postalAddress; DirPartyLocation partyLocation; LogisticsAddressCountryRegion addressCountryRegion; CustVendAC custVendAcc; utcDateTime startDateTime, endDateTime; TestTable_t testTable; #define.SPP('URL')//TODO:Testing startDateTime = DateTimeUtil::applyTimeZoneOffset(DateTimeUtil::getSystemDateTime(), DateTimeUtil::getCompanyTimeZone()); endDateTime = DateTimeUtil::addYears(startDateTime, -1); while select createdBy, createdDateTime, TypeId from docuRef where docuRef.RefTableId == tableNum(CustTable) && docuRef.RefCompanyId == curext() && (docuRef.createdDateTime >= startDateTime && docuRef.createdDateTime <= endDateTime && docuRef.TypeId == #SPP) || docuRef.TypeId != #SPP join AccountNum, Party from custTable where custTable.RecId == docuRef.RefRecId && custTable.Blocked == CustVendorBlocked::No exists join partyLocation where partyLocation.IsPrimary == true && partyLocation.Party == custTable.Party exists join postalAddress where postalAddress.Location == partyLocation.Location exists join addressCountryRegion where addressCountryRegion.CountryRegionId == postalAddress.CountryRegionId && addressCountryRegion.SanctionedCountry_mb == NoYes::Yes { tmpCustVendListTable.clear(); testTable.clear(); if (custVendAcc != custTable.AccountNum) { custVendAcc = custTable.AccountNum; } else { if (docuRef.TypeId != #SPP) continue; } tmpCustVendListTable.BPAccountNum = custVendAcc; tmpCustVendListTable.BPName = custTable.name(); testTable.BPAccountNum = custVendAcc; testTable.BPName = custTable.name(); testTable.TypeId = docuRef.TypeId; if (docuRef.TypeId == #SPP) { tmpCustVendListTable.ResponsibleUser = XUserInfo::find(false, docuRef.createdBy).name; tmpCustVendListTable.ScreeningDateTime = docuRef.createdDateTime; testTable.ResponsibleUser = XUserInfo::find(false, docuRef.createdBy).name; testTable.ScreeningDateTime = docuRef.createdDateTime; } tmpCustVendListTable.insert(); testTable.insert(); } } |
| Теги |
| axapta 2012, docuref, missing value, ssrs, typeid |
