Старый 29.12.2019, 01:27   #1
sinedax: Create Financial Reporting App - Dynamics 365 for Finance & Operations LBD
Источник: http://sinedax.blogspot.com/2019/12/...-dynamics.html
Hi LBD enthusiastic,
here I'm sharing the steps that we need to follow in order to install manually the Financial Reporting App.
Walk through the MR Node and follow those steps:
  • If present with error, delete the FR app from the Fabric or run the following command with 3 parameters:
    \\fileserver\Agent\wp\Environment\StandaloneSetup-xxxxxx\Apps\FR\Deployment\FinancialReportingDeployer.exe \\fileserver\Agent\wp\Environment\StandaloneSetup-xxxxxx\\config.json \\fileserver\Agent\wp\Environment\StandaloneSetup-xxxxxx Cleanup
  • If needed, remove also the FR Database (take a backup first) and configure it again. About the installation, go through the link https://docs.microsoft.com/en-us/dyn...rting-database
  • Install the FR App:
    \\fileserver\Agent\wp\Environment\StandaloneSetup-xxxxxx\Apps\FR\Deployment\FinancialReportingDeployer.exe \\fileserver\Agent\wp\Environment\StandaloneSetup-xxxxxx\config.json \\fileserver\Agent\wp\Environment\StandaloneSetup-xxxxxx Setup
Thank you also to Uwe Zimmermann, MS LBD guru.
Till now!
sinedax: App Fabric Certificates Details - Dynamics 365 for Finance & Operations LBD Blog bot DAX Blogs 0 22.01.2019 10:11
sinedax: Maintenance mode - Dynamics 365 for Finance & Operations LBD Blog bot DAX Blogs 0 24.07.2018 20:12
powerobjects: Electronic Reporting in Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 14.02.2018 03:28
Часовой пояс GMT +3, время: 01:04.
