Старый 28.05.2020, 14:11   #1
25,644 / 848 (80) +++++++
ax.docentric: Comment on Webinar: Electronic Reporting Basics Through Simple Example by Radhika
Источник: https://ax.docentric.com/attend-webi.../#comment-1041
Hi Albin Lotrič,I tried following a similar logic for building a report, only difference being the Excel format use instead of XML format. But I am getting a one-liner report instead of the date range..... Could you guide us on the same?
Старый 28.05.2020, 21:11   #2
ax.docentric: Comment on Webinar: Electronic Reporting Basics Through Simple Example by Albin
Источник: https://ax.docentric.com/attend-webi.../#comment-1044
I am happy to hear that you were able to troubleshoot your report that fast. I invite you to watch our other videos to learn more about ways how we use and improve Electronic Reporting.
Старый 28.05.2020, 21:11   #3
Источник: https://ax.docentric.com/attend-webi.../#comment-1043
OH! yes, I guess I missed on the part where i needed to define name for the Page range too and then bind it with record list.... now I am getting the entire list as per the from date- to date parameters put in......Thanks for the input....
Старый 28.05.2020, 21:11   #4
Источник: https://ax.docentric.com/attend-webi.../#comment-1042
Hi Radhika,Check the node type of the data model first. If it will contain several records its type should be Record list. Next check that the binding in the Model mapping designer is bound to the data source which returns a list of records.On the Format part, your Excel template has to contain a named range of cells which has to be mapped to a data model's Record list element, mentioned earlier. Individual named cells within the range should be mapped to the elements within the record list.You can check our other Electronic Reporting webinars where some of these principles are explained in real-world scenarios (e.g. https://ax.docentric.com/webinar-cre...pecs-using-er/)
ax.docentric: Comment on Report Viewer in Dynamics 365 for Finance and Operations On-Premises by Jure Leskovec Blog bot DAX Blogs 0 09.03.2020 07:21
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
Часовой пояс GMT +3, время: 06:39.
