Старый 10.09.2021, 19:13   #1
d365technext: Sysoperation VS RunBase
Источник: https://d365technext.blogspot.com/20...VSRunbase.html
What is the Sysoperation framework how it is different from the runbase framework?
In Microsoft Dynamics AX 2012 & D365FO, the SysOperation system supplanted the RunBase system to bolster the group preparing usefulness. Going forward, the SysOperation system is prescribed for composing custom trade rationale that requires clump handling usefulness, over the censured RunBase framework. The RunBase system characterizes coding designs that actualize these necessities. The SysOperation system gives base executions for numerous of the designs characterized by the RunBase system. Another incredible thing is SysOperation system streamlined the pack / unload of factors that were extra work within the RunBase system, taking advantage of the Traits highlight presented with AX 2012 & D365FO.
SysOperation framework allows application logic to be written in a way that supports running operations interactively or via the Microsoft Dynamics AX & D365FO batch server. It implements the MVC (Model–View–Controller) design pattern, with the isolation of Parameters (Model), Dialog (View), and Service (Controller), for the code that’s executed.
The key objects of the framework are defined below:
Service:
The service class extends from the SysOperationServiceBase class and contains the business logic for the batch operation. Developers often tend to add the business logic in controller classes, which violates the Single responsibility principle.
Data Contract:
Data contract class is the model class defining attributes needed for batch operations. These attributes are provided by the user, in a dialog. DataContractAttribute attribute is needed for the class and the properties methods require the DataMemberAttribute attribute.
Controller:
Controller class extends from the SysOperationServiceController class. It holds information about the batch operation like execution mode, show dialog or progress bar etc. and directs the batch operation.
UI Builder:
UI Builder class extends from SysOperationAutomaticUIBuilder class and is used for adding custom behavior to dialog/dialog fields dynamically constructed by the SysOperation framework.
Runbase vs SysOperation wojzeh DAX: Программирование 23 16.01.2019 14:17
stoneridgesoftware: Batch Processing in Dynamics AX 2012 Using SysOperation Framework Blog bot DAX Blogs 0 28.03.2017 00:11
daxmusings: From RunBase to SysOperation : Business Operation Framework (Cont'd) Blog bot DAX Blogs 0 19.08.2011 16:11
daxmusings: From RunBase to SysOperation : Business Operation Framework Blog bot DAX Blogs 4 17.08.2011 16:01
Inside Dynamics AX 4.0: RunBase Framework Extension Part IV Blog bot DAX Blogs 0 02.10.2007 04:49
Часовой пояс GMT +3, время: 10:34.
