Старый 11.03.2023, 04:34   #1
How to export/import Tax registration numbers for Vendors
Источник: http://alexvoy.blogspot.com/2023/03/...istration.html
D365FO contains a special data entity which can be used for both DMF export/import and also in Excel Add-in, but...
There is an interesting InnerJoin inside of this data entity, which may be a hurdle for understanding why you still have no records exported; nevertheless, you have some in TaxRegistration table.
In fact, when you create records in Vendor Registration IDs form, it does not tell you about this constraint.
To get these records exported, you simply need to add it in Registration categories.
and voila!
stoneridgesoftware: How to Import or Export a Customized Security Configuration Using Data Management in D365 Finance and Supply Chain Blog bot DAX Blogs 0 21.05.2021 17:11
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
alexef: Sample Extension v2.0 — Dynamics NAV / AL extension / SaaS — ALF Export Setup Tabs to Excel Blog bot NAV: Blogs 3 05.10.2018 23:13
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Часовой пояс GMT +3, время: 16:47.
