Старый 02.03.2006, 11:32   #1
raz is offline
raz
NavAx
Аватар для raz
NavAx Club
1,500 / 1098 (40) ++++++++
Сообщение от korvin
Проверил, не совсем то, вернее совсем не то получается, что в задаче
А что не то?
Свиду вроде все нормально.
info вот что выдает:
SELECT * FROM Table1 GROUP BY Table1.StorageId ASC, Table1.WareId ASC, Table1.PartyId ASC WHERE ((StorageId = 000 OR StorageId = 001)) AND ((WareId = 002 OR WareId = 003)) JOIN SUM(AmountMod), SUM(CostMod) FROM Table1 WHERE Table1.StorageId = Table1.StorageId AND Table1.WareId = Table1.WareId
Планы запросов только скобками отличаются:
SELECT A.STORAGEID,A.WAREID,A.PARTYID,SUM(B.AMOUNTMOD),SUM(B.COSTMOD)
FROM TABLE1 A,TABLE1 B
WHERE ((A.DATAAREAID='DAT')
AND (((A.STORAGEID='000') OR (A.STORAGEID='001'))
AND ((A.WAREID='002') OR (A.WAREID='003'))))
AND ((B.DATAAREAID='DAT')
AND ((A.STORAGEID=B.STORAGEID)
AND (A.WAREID=B.WAREID)))
GROUP BY A.STORAGEID,A.WAREID,A.PARTYID
ORDER BY A.STORAGEID,A.WAREID,A.PARTYID OPTION(FAST 22)
WHERE (A.DATAAREAID='DAT')
AND (((((A.STORAGEID='000') OR (A.STORAGEID='001'))
AND (B.STORAGEID=A.STORAGEID))
AND (B.WAREID=A.WAREID)))
PHP код:
static void Job39(Args _args)
Table1                          wp0;
Table1                          wp1;
Table1                          wp0_q;
Table1                          wp1_q;
StorageId                xxx "000";
StorageId                yyy "001";
WareId                zzz "002";
WareId                aaa "003";
Query                           query = new Query();
QueryBuildDataSource            qbds1qbds2;
QueryRun                        QueryRun;
select from wp0 group by StorageIdWareIdPartyId
    join sum
(AmountMod), sum(CostModfrom wp1
    where
(wp0.StorageId == xxx || wp0.StorageId == yyy) &&
wp0.WareId == zzz || wp0.WareId == aaa) &&
wp1.StorageId == wp0.StorageId &&
wp1.WareId == wp0.WareId;
qbds1 query.AddDataSource(tablenum(Table1));
qbds1.ordermode(ordermode::groupby);
qbds1.addSortField(fieldnum(Table1StorageId));
qbds1.addSortField(fieldnum(Table1WareId));
qbds1.addSortField(fieldnum(Table1PartyId));
qbds1.addrange(fieldnum(Table1StorageId)).value(xxx "," yyy);
qbds1.addrange(fieldnum(Table1WareId)).value(zzz "," aaa);
qbds2 qbds1.AddDataSource(tablenum(Table1));
qbds2.ordermode(ordermode::groupby);
qbds2.addSelectionField(fieldnum(Table1AmountMod), selectionField::Sum);
qbds2.addSelectionField(fieldnum(Table1CostMod), selectionField::Sum);
qbds2.addLink(fieldnum(Table1StorageId), fieldnum(Table1StorageId));
qbds2.addLink(fieldnum(Table1WareId), fieldnum(Table1WareId));
info(query.dataSourceNo(1).toString());
QueryRun = new QueryRun(query);
QueryRun.next();
wp0_q QueryRun.getNo(1);
wp1_q QueryRun.getNo(2);
Последний раз редактировалось raz; 02.03.2006 в 11:38.
Старый 02.03.2006, 11:51   #2
korvin is offline
korvin
Аватар для korvin
29 / 10 (1) +
Сообщение от raz
А что не то?
PHP код:
Table1                          wp0;
Table1                          wp1;
Table1                          wp0_q;
Table1                          wp1_q;
WareId                zzz "002";
WareId                aaa "003";
QueryRun                        QueryRun;
    join sum
    where
QueryRun.next();
Извиняюсь был неправ, ошибся у себя в условии, ваш пример отлично работает!
Беру на вооружение. Жаль только что уже сделал через XppCompiler, переработал лишнего...
Все люди равны, но некоторые равнее...
query, программно
Advanced query range value expressions: поле таблицы - имя вcтроенной функции year(). ATimTim DAX: Программирование 12 27.03.2009 18:16
Как подставить вычисляемое значение в Range у query Poleax DAX: Программирование 16 17.06.2008 18:52
Что и как можно резать? George Nordic DAX: Администрирование 1 11.05.2004 18:44
можно ли сделать с помощью join следующий запрос: SergAY DAX: Программирование 1 29.07.2003 11:39
Часовой пояс GMT +3, время: 06:12.
