Старый 11.04.2006, 07:12   #1
Sada is offline
Sada
Программатор
Аватар для Sada
1,450 / 153 (8) ++++++
Не могу понять в чем ошибка???
Доброго всем времени суток, уважаемые коллеги.
есть вот такой кусок кода:
PHP код:
   Query                                 q = new Query();
QueryBuildDataSource        ds,ds2,ds3;
queryRun                            qr;
ds q.addDataSource(tablenum(InventTrans));
ds.addSelectionField(fieldnum(InventTrans,TransType));
ds.addSelectionField(fieldnum(InventTrans,StatusIssue));
ds.addSelectionField(fieldnum(InventTrans,DateStatus));
ds.addSelectionField(fieldnum(InventTrans,ItemId));
ds.addSelectionField(fieldnum(InventTrans,InventTransId));
ds.addSelectionField(fieldnum(InventTrans,Qty));
ds.addSelectionField(fieldnum(InventTrans,CustVendAC));
s"((inventTrans.StatusIssue == statusIssue::Sold || inventTrans.StatusReceipt == statusReceipt::Purchased))";
q.dataSourceTable(TableNum(InventTrans)).addRange(FieldNum(InventTrans,recId)).value(s);
ds.addRange(fieldNum(InventTransDateStatus)).value(sysQuery::range(PlanDateFromPlanDateTo));
ds.addRange(fieldNum(InventTransTransType)).value(QueryValue(InventTransType::Sales));
ds.orderMode(OrderMode::OrderBy);
ds.addSortField(fieldnum(InventTransItemId));
ds2 ds.addDataSource(tableNum(CustInvoiceTrans));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,InventTransId));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,Scrap));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,SalesPrice));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,Qty));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,LineAmount));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,TaxAmount));
ds2.joinMode(JoinMode::InnerJoin);
ds2.fetchMode(0);
ds2.addLink(fieldNum(InventTrans,InventTransId),fieldNum  (CustInvoiceTrans,InventTransId));
ds3 ds.addDataSource(tablenum(CustTable));
ds3.relations(true);
ds3.joinMode(JoinMode::InnerJoin);
ds3.fetchMode(0);
ds3.addSelectionField(fieldnum(CustTable,Name));
ds3.addSelectionField(fieldnum(CustTable,Agent));
qr = new QueryRun(q);
    while (
qr.next())
обработка данных..
на эту конструкцию мне Аксапта выдает "Ошибка расширенного диапазона запроса: inventTrans.StatusIssue не является корректной парой datasource.field рядом с 30
Подскадите плиз, что бы это значило. ошибка появляется на строке while (qr.next())....
C Уважением - Sada...
Старый 11.04.2006, 08:39   #2
TasmanianDevil is offline
TasmanianDevil
Мрачный тип
Аватар для TasmanianDevil
887 / 389 (14) ++++++
Обычный бред Аксапты на очевидную ошибку
Все Range.Value - строки , т.е. надо написать s="Продано,Куплено"
Последний раз редактировалось TasmanianDevil; 11.04.2006 в 08:43.
Старый 11.04.2006, 08:52   #3
Sada is offline
Sada
Программатор
Аватар для Sada
тоесть нада вот это исправить
s= "((inventTrans.StatusIssue == statusIssue::Sold || inventTrans.StatusReceipt == statusReceipt::Purchased))";
но на ЧТО?(попробовал не получилось...)
Старый 11.04.2006, 08:57   #4
TasmanianDevil
Мрачный тип
Сообщение от Sada
прошу прощения, не разобрался - Вы в фильтре хотите наложить ограничения на два поля , а не на одно
Скобочки одинарные, OR и просто имена полей не помогают ?
Последний раз редактировалось TasmanianDevil; 11.04.2006 в 09:12.
Старый 11.04.2006, 09:03   #5
Sada is offline
Sada
Программатор
Аватар для Sada
Сообщение от TasmanianDevil
прошу прощения, не разобрался - Вы в фильтре накладываете ограничения на два поля , а не на одно
В любом случае в значение фильтра по полю имеющему перечислимы тип - есть строка, и пихать туда надо именно строковое значение соответствующего числового значения перечислимого типа
да на два, и мне именно нада чтоб был OR...
Старый 11.04.2006, 09:13   #6
Sada is offline
Sada
Программатор
Аватар для Sada
Хелп...
Старый 11.04.2006, 09:29   #7
AndyD is offline
AndyD
КОРУС Консалтинг
2,560 / 2494 (89) +++++++++
Во-первых, добавьте имя датасоурса
    ds = q.addDataSource(tablenum(InventTrans), "InventTrans");
Во-вторых, добавьте скобки
s= "((inventTrans.StatusIssue == statusIssue::Sold) || " +
    "(inventTrans.StatusReceipt == statusReceipt::Purchased))";
В-третьих, TransType устанавливайте так
ds.addRange(fieldNum(InventTrans, TransType)).
    value(int2str(InventTransType::Sales));
или так
    value("(InventTrans.TransType == InventTransType::Sales)");
Axapta v.3.0 sp5 kr2
Старый 11.04.2006, 09:35   #8
AndyD is offline
AndyD
КОРУС Консалтинг
Пардон, то, что в-третьих можно не делать
Старый 11.04.2006, 09:43   #9
Sada is offline
Sada
Программатор
Аватар для Sada
2AndyD
Спасибо огромное, теперь буду знать!!!Все заработало
В чем ошибка???? a-da DAX: Программирование 3 08.04.2007 00:17
Ошибка при запуске 3-tier nicko DAX: Администрирование 3 02.02.2007 13:44
Ошибка при обработке С-Ф Sergo DAX: Программирование 7 20.01.2006 11:56
Ошибка при закрытии склада, при закрытии более ранней датой, чем пересчет Berkoff DAX: Функционал 2 25.10.2004 17:52
Ошибка при сохранении поставщика Filip DAX: Функционал 19 24.02.2004 08:32
Часовой пояс GMT +3, время: 17:17.
