Старый 28.10.2006, 16:40   #1
Solutions Monkey: Quick Steps to setup Enterprise Portal in a cluster
Источник: http://blogs.msdn.com/solutions/arch...27/774400.aspx
  1. Set Up NLB cluster with 2 Win2003 servers (server1 server2)
  2. Install IIS & ASP.NET 2.0 on both servers
  3. ?Install WSS on both servers
  4. Deploy EP on both server
  5. Set the APP pool to use BC proxy account and set the trust level in web.config
  6. Server1: created the config database and extended the default website to create content database
  7. Server2: connected to the config created by Server1 and chose to: ‘Extend and map to another virtual server’ where we connected to the website on Server1
  8. Create EP site in Server1 and grant UserRelation Web Access in AX.
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal Quick starts and Screen casts Blog bot DAX Blogs 0 05.08.2008 05:18
Solutions Monkey: Enterprise Portal Screencasts at Channel9.msdn.com Blog bot DAX Blogs 6 01.07.2008 19:38
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Solutions Monkey: Opening Enterprise Portal page in a new window from the Quick Launch Blog bot DAX Blogs 0 06.10.2007 06:51
Часовой пояс GMT +3, время: 04:28.
