Старый 28.10.2006, 16:40   #1
Solutions Monkey: EP Web Part connection
Источник: http://blogs.msdn.com/solutions/arch...11/662556.aspx
In the EP , Web Menu and Web Form Web Parts use SharePoint Web Part connection mechanism to pass the information required to identify a record in Dynamics AX Database known as record context to the pages invoked by menu items. The Web Form Web Part implements the ICellProvider interface, and the Web Menu Web Part implements the ICellConsumer interface. In the EP, the Web Part connection is an optional technique that is used when the menu needs to get the context from the Web form to pass to the invoked menu item, or when the Web form needs to control the elements displayed on the Web menu. Web Part connections are based on the notion of providers and consumers. The Web Form Web Part is the provider of record context, and the Web Menu Web Part is the consumer of this information when the Web Part connection is enabled. showMenuFunction , setMenuFunctionRecord , callMenuFunction are the important methods in the connected Web forms related to Web Part connection.
Solutions Monkey: Integrating EP Web Parts to non-EP SharePoint sites Blog bot DAX Blogs 0 04.04.2009 03:19
Solutions Monkey: KPIs in Role Center Business Overview Web Part keeps loading all the time and never ends. Blog bot DAX Blogs 0 12.03.2009 07:05
Solutions Monkey: Ax Report Web Part properties Blog bot DAX Blogs 0 10.10.2008 06:06
Solutions Monkey: EP Configuration - Single Web Server & Multiple AOS installations Blog bot DAX Blogs 0 28.10.2006 16:40
Solutions Monkey: EP 4.0 Questions Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 17:28.
