Старый 28.10.2006, 16:40   #1
Karl Tolgu: Is the .NET Business Connector in Dynamics AX 4.0 just a wrapper on the previous COM Connector?
Источник: http://blogs.msdn.com/katolgu/archiv...07/571182.aspx
Here is a post that neatly summarizes the changes (concerning Business Connector) in the Dynamics AX 4.0 release.
In the comments section of the linked post, I also see one of the questions I commonly get: "is the .NET Business Connector simply a wrapper on the Axapta 3.0 COM Connector?"
The answer is - no. The managed layer (which contains the managed classes you use to build applications) was written from scratch, as was the transition layer that maps objects in the managed world to the Dynamics AX 4.0 X++ based world.
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
ALEG: Проект "Фишка недели" и первый пост - Microsoft Dynamics™ AX .NET Business Connector Blog bot DAX Blogs 1 22.11.2006 09:43
Часовой пояс GMT +3, время: 19:05.
