Старый 17.01.2007, 13:44   #1
George Nordic is offline
George Nordic
Аватар для George Nordic
4,480 / 1255 (50) ++++++++
Записей в блоге: 9
SQL Server 2005 Features Comparison
The table below presents details about each of the different editions.
In the following table, the "Comments" column provides comments on the specified feature. Numbers next to check marks indicate footnotes that appear at the bottom of the page. SQL Server 2005 Developer Edition and Evaluation Edition are not listed in the tables. These editions have the same feature set as the Enterprise Edition; the only difference between these editions is the licensing policies.
http://www.microsoft.com/sql/prodinf...-features.mspx
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
aEremenko: Нужно ли использовать секционирование в Microsoft SQL Server 2005 для DAX 3.0 Blog bot DAX Blogs 5 27.03.2007 09:37
Сергей Герасимов: О совместимости Microsoft SQL Server 2005 и Microsoft Dynamics AX 3.0 Blog bot DAX Blogs 0 26.02.2007 12:40
aEremenko: Диагностика проблем при установке Microsoft Dynamics Ax 4.0 на Microsoft SQL Server 2005 Blog bot DAX Blogs 0 28.10.2006 16:01
Часовой пояс GMT +3, время: 10:33.
