Старый 21.02.2007, 16:00   #1
Kashperuk Ivan: Dynamics AX TutorialsHello, everyone.I was goi...
Источник: http://kashperuk.blogspot.com/2007/0...-everyone.html
Hello, everyone.
I was going through the Jobs node in my application recently, and stumbeled upon a lot of good examples of different programming technics. I thought it would be nice to share what I have :)
So with this post I will start a series of tutorials on Axapta development.
Today's post is about selecting multiple records on a form (using checkboxes instead of standard Axapta method)
The homepage for this tutorial in on Axaptapedia
It is a simple tutorial form based on InventTable datasource. You can select multiple lines and process the lines by pressing Process lines button.
Here is a short list of what is covered in the tutorial besides the main point of processing selected lines:
  1. Using edit methods in a grid of a form.
  2. Using Foundation class Set to collect selected lines.
  3. Using SetIterator class to go through elements of a Set object.
Preview of the form
download, как правильно, полезное, производительность, axapta
Kashperuk Ivan: Microsoft Dynamics AX 2009 Keyboard shortcuts Blog bot DAX Blogs 5 18.12.2013 18:24
Kashperuk Ivan: My first attempts in Dynamics AX 4.0 SP1 Blog bot DAX Blogs 19 28.08.2009 15:48
Kashperuk Ivan: Now I am a MCBMSS in Dynamics AX Blog bot DAX Blogs 0 07.05.2007 18:40
Kashperuk Ivan: Dynamics AX Tutorials - Tutorial 2 - Classes\Box Blog bot DAX Blogs 0 25.04.2007 22:23
Часовой пояс GMT +3, время: 16:34.
