Старый 14.05.2007, 18:00   #1
axaptapedia: DEV TabaxPlugin OpenInAOT
Источник: http://www.axaptapedia.com/DEV_TabaxPlugin_OpenInAOT
Summary: /* Download */
=== DEV_TabaxPlugin_OpenInAOT ===
This is a very simple plugin for [[Tabax]]
Code is based on [[Editor_scripts_OpenInAOT]]
This tool is available only to developers (SysDevelopment security key).
=== Download ===
version 0.1 - [http://www.axaptapedia.com/images/a/..._OpenInAOT.xpo download]
=== Requirements ===
[[Tabax]] version 0.3 or higher is needed for the Plugin to work
=== Installation instructions ===
Import the project and refresh the AOD (this is specifically needed for the rich AX4 client)
Now you can open AOT objects just by typing their name in the Tabax form edit box (prefixed with ‘go’).
=== Examples ===
“go InventTable” will open the Tables\InventTable node.
“go InventDimDevelop” will open the Macros\InventDimDevelop, etc.
axaptapedia: DEV QueryBrowser Blog bot DAX Blogs 0 15.10.2007 21:30
axaptapedia: DEV TabaxPlugin RecentWindows Blog bot DAX Blogs 0 14.05.2007 18:00
axaptapedia: DEV TabaxPlugin RecentProjects Blog bot DAX Blogs 0 14.05.2007 18:00
dynamicsmatters: Dev for Localization Cost of dev Blog bot DAX Blogs 0 21.11.2006 22:51
Часовой пояс GMT +3, время: 01:49.
