Старый 28.06.2007, 17:00   #1
axaptapedia: Polymorphism
Источник: http://www.axaptapedia.com/Polymorphism
Summary: New page: Polymorphism is a core concept in OO and goes hand in hand with [[:inheritance]]. You can use an object from typ of a subclass always like an object from type of a superclass. By example i...
Polymorphism is a core concept in OO and goes hand in hand with [[:inheritance]]. You can use an object from typ of a subclass always like an object from type of a superclass. By example if you create a class that extends RunBaseBatch you can use it always like a RunBaseBatch Object
class MyBatch extends RunBaseBatch
RunBaseBatch batch = new MyBatch();
batch.run();
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axaptapedia: OOP Blog bot DAX Blogs 0 20.06.2007 23:13
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 23:32.
