Старый 15.12.2007, 01:11   #1
axStart: Synchronizing dictionary gives unclear errors
Источник: http://axstart.spaces.live.com/Blog/...C0A0!176.entry
<div>
Sometimes synchronizing give strange unclear errors. Most of the time the issue can be solved by reindexing the database. But even that will not solve the issue sometimes.
So the solution we need is a better information witch table is not synchronizing.
This can be done by changing method dbSynchronize in the application class.
Solution has been created by Kevin Deegens (thanks Kevin!)
boolean dbSynchronize(tableId tableId         = 0,   // 0 = all tables, non-zero is a valid table handle
                      boolean syncAsNeeded    = true,  // true = objects touched in the AOT, false = unconditional synchronize
                      boolean continueOnError = true,
                      boolean showProgress    = true ) // true = report all problems, but throw only after all tables are synchronized, false = stop synchronize after first error/problem
    boolean         ok;
// PRO, 23.08.2007, KDE begin
    SysOperationProgress    progressBar = new SysOperationProgress();
    Dictionary              dictionary  = new Dictionary();
    DictTable               dictTable;
    int                     totalNumOfTables;
    TableId                 tableIdNum;
    int                     i;
    str                     infoLogTxt;
    container               infoLogText;
// PRO, 23.08.2007, KDE end
    setprefix("@SYS22807");
    if (syncAsNeeded)
        ok = super(tableId, syncAsNeeded, continueOnError, showProgress);
    else
        totalNumOfTables = dictionary.tableCnt();
        progressBar.setCaption("Tabel synchroniseren");
        progressBar.setTotal(totalNumOfTables);
axStart: table & field ID conflicts Blog bot DAX Blogs 0 29.05.2008 17:05
axStart: SQL Synchronize trouble, work around Blog bot DAX Blogs 0 18.12.2007 20:40
axStart: Mass update on table properties Blog bot DAX Blogs 0 15.12.2007 01:11
gatesasbait: On data dictionary synchronization errors Blog bot DAX Blogs 0 29.11.2007 00:53
Часовой пояс GMT +3, время: 04:55.
