Старый 18.01.2008, 16:30   #1
axStart: Test script for your .Net Connector
Источник: http://axstart.spaces.live.com/Blog/...C0A0!243.entry
Her is a test script So you can test if the connector is working in Sharepoint.
static void Main(string[] args)
            System.Net.NetworkCredential proxyaccount = new System.Net.NetworkCredential("administrator", "
pass@word1");
            Axapta a = new Axapta();
            try
                a.LogonAs("administrator", "DynamicsAX0", proxyaccount, "", "", "", "");
                System.Console.WriteLine("logon succeded, press any key to continue");
                System.Console.ReadKey();
                a.Logoff();
            catch(Exception ex)
                System.Console.WriteLine(ex.ToString());
                System.Console.WriteLine("logon failed, press any key to continue");
msdynamicsax: VB script that test the com connector for Dynamics Ax 4.0 Blog bot DAX Blogs 0 25.08.2008 18:05
axStart: A structure way off dealing with garbage collection & memory leaks with the Dynamics AX .net connector. Blog bot DAX Blogs 0 31.07.2008 22:05
axStart: Using base enums in your .net connector Blog bot DAX Blogs 0 30.07.2008 00:05
ALEG: Проект "Фишка недели" и первый пост - Microsoft Dynamics™ AX .NET Business Connector Blog bot DAX Blogs 1 22.11.2006 09:43
Часовой пояс GMT +3, время: 04:39.
