Старый 23.01.2008, 22:30   #1
axStart: mailing a PDF attachment
Источник: http://axstart.spaces.live.com/Blog/...C0A0!248.entry
First add the primary record type to the class EPSendDocument, method new
case tablenum(WEBCaseStudy) :
mailAddress = CustTable::find(record.(fieldnum(WEBCaseStudy,custAccount))).Email;
custAccountNum = record.(fieldnum(WEBCaseStudy,custAccount));
documentTitle = fileName("@SYS13960");
reportName = reportstr(CustRevenue);
break;
default:
Next fix a MS bug in the same method
Add in the declaration of the new method this line
//WEB MS BUG
str path = SysEPDeployment::getSharepointTemplatePath() + #layoutsDirPath + #epDirPath + #imagesDirPath;
//WEB MS BUG
Next add bellows line for all comment out line of files and SendFile
file = path+'\document'+time+#pdf;
sendFile = path + '\'+documentTitle+#pdf;
Finally you can mail it this way
EPSendDocument document;
document = new EPSendDocument(WebCaseStudy);//your table need property ‘titleField1’ to be set
document.makeDocument();
EPSendDocument::sendMail(document.emailId(), document.parmMailAddress(), document.parmSendFileName(), document.mailLanguage());
if (document.isGenerated())
winApi::deleteFile(document.parmFileName());
create Pdf invoice report DmitrySincerity DAX: Программирование 1 25.03.2009 17:27
axStart: Get your forms back in one workspace Blog bot DAX Blogs 0 10.12.2008 14:05
axStart: Application logging with stack traces integration. Blog bot DAX Blogs 0 18.03.2008 17:05
C# and AX Development: Printing directly to PDF in AX Blog bot DAX Blogs 0 18.03.2008 03:14
Часовой пояс GMT +3, время: 22:53.
