Старый 27.01.2008, 07:06   #1
axStart: Use Microsoft Dynamics AX debugger in Visual Studio.
Источник: http://axstart.spaces.live.com/Blog/...C0A0!250.entry
It is possible to Debug AX by using the AX.net connector. Even if we communicate with an AX webservice.
1. Create your breakpoint in AX with the same user you are connecting AX from Visuals Studio. You have to do this by typing the word breakpoint in your code.
2. Start the AX debugger manual
3. Run your C# code
4. AX will stop at the keyword breakpoint in the Debugger.
This also works for AIF (place breakpoint word at method in the AXDclass of the interface
This also works for the Enterprise portal.
Dynamics AX: Microsoft's strategy and vision for Dynamics AX and SOA Blog bot DAX Blogs 0 05.03.2009 18:05
axStart: Date methods in your Visual Studio Dynamics AX Report. Blog bot DAX Blogs 0 10.09.2008 23:05
axStart: Microsoft Dynamics AX 2009 White Paper: Team Foundation Server Version Control Setup Blog bot DAX Blogs 0 27.07.2008 13:06
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 06:54.
