Старый 04.02.2008, 13:52   #1
pkost is offline
pkost
? ISV Integration в MS CRM 4
Доброе время суток. Подскажите пожалуйста как включить ISV Integration в MS CRM 4?
Быть в курсе всего первым - значит быть Первым!
Старый 04.02.2008, 16:01   #2
ShurikEv is offline
ShurikEv
CRM
213 / 28 (1) +++
Enabling Your Customizations
To enable your customizations, in the Navigation Pane, click Settings, click Administration, and then click System Settings. Select the Customization tab. In the Custom menus and toolbars area, set the Clients value to include the clients to enable custom controls. You can select any combination of clients.
The available clients are as follows:
  • Outlook (Microsoft Dynamics CRM for Microsoft Office Outlook)
  • Outlook Offline (Microsoft Dynamics CRM for Microsoft Office Outlook with Offline Access)
  • Web Application
The Custom menus and toolbars setting is used as a performance optimization. When there are no client extensions to be rendered, no clients should be selected.
Microsoft CRM: Sharepoint integration with MS CRM 4.0 Blog bot Dynamics CRM: Blogs 0 05.02.2009 14:05
Microsoft Dynamics CRM Team Blog: (Simplified) Pivot Table Integration Blog bot Dynamics CRM: Blogs 0 27.09.2008 02:05
Microsoft CRM Integration: Oracle Database Access from MS CRM pkost Dynamics CRM: Разработка 2 09.11.2006 17:44
Часовой пояс GMT +3, время: 04:04.
