Старый 09.02.2008, 06:57   #1
axStart: Make country configuration key company depended.
Источник: http://axstart.spaces.live.com/Blog/...C0A0!256.entry
When we enable multiple country configuration keys (CRSEcountry). The configuration key is enabled for all countries. This means that for example Belgium Law requirements influence German Law requirements. For a lot of those country specific configuration keys, no additional security keys are defined. However it is still possible to enable configuration key in relation to there company.
In AX most configuration checks in classes are done by this method in the global class
static boolean isConfigurationkeyEnabled(configurationKeyId configurationkey)
    DictConfigurationKey dictConfigurationKey = new DictConfigurationKey(configurationkey);
    if (dictConfigurationKey && !dictConfigurationKey.enabled())
        return false;
    return true;
It is possible to make above code also company depended. We can do this by adding the field configurationKeyId to the company table.
        return false;
    if(dictConfigurationKey.parentConfigurationKeyId() == configurationkeynum(CRSECountry) &&
      companyinfo::find().configurationKeyId != configurationkey)
      return false;
    return true;
I used this trick on a project in Axapta 3.0 where we had to merge Europe, USA, Canada, Mexico and Australia.
axStart: Import 3.0 company data into 4.0 Blog bot DAX Blogs 0 31.01.2008 20:50
axStart: AXC configuratied SharePoint AX configuration. Blog bot DAX Blogs 0 17.01.2008 03:30
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Configuration key в EDT Hezl DAX: Программирование 4 04.08.2004 11:53
Часовой пояс GMT +3, время: 23:33.
