Старый 28.04.2008, 19:05   #1
Kashperuk Ivan: SysFormEnumComboBox - class allowing to show only some of the values for a comboBox
Источник: http://kashperuk.blogspot.com/2008/0...lowing-to.html
In Microsoft Dynamics AX 2009, a new class has been created, that got my attention recently after yet another question about this sort of thing was asked by a fellow Dynamics AX developer.
Often enough, we need to restrict the user selection from a particular ComboBox. Creating a new BaseEnum specifically for this purpose is a really cumbersome solution, which later might lead to problems of maintenance.
Originally, the SysFormEnumComboBox was designed to be used on forms to provide for this behavior. I modified the class slightly to allow for usage in RunBase Framework classes.
To demonstrate, how this class can be used, I modified the tutorial_RunBaseForm class and form, showing both scenarios: adding the control from the dialog method of the class, as well as adding it manually in the form design and methods.
To use this class, you need to know only one static method:
public static SysFormEnumComboBox newParameters(
    FormRun _formRun,
    int     _comboBoxControlId,
    enumId  _enumId,
    Set     _allowedEnumValuesSet,
    Form    _form = null)
And here is an example of how you would use it:
sysFormEnumComboBox = SysFormEnumComboBox::newParameters(element,
    control::ComboBoxOnForm,
    enumnum(InventTransType),
    enumSet);
which means that the control ComboBoxOnForm will be bound to BaseEnum InventTransType, containing only values, found in the Set enumSet.
You can download the project for versions 4.0 and 2009 of Microsoft Dynamics AX through the following link:
download
P.S. It is also worth mentioning, that this class does not provide support for grids. It requires a stand-alone control, not bound to a database table field.
Kashperuk Ivan: SysInfoAction class description - Improve your Infolog Blog bot DAX Blogs 0 17.09.2008 03:23
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Kashperuk Ivan: A bug in validation of methods' access modifiers and class abstract modifier Blog bot DAX Blogs 0 27.06.2007 21:40
Kashperuk Ivan: Description of ClassBuild class:Today I want to ... Blog bot DAX Blogs 0 26.01.2007 05:51
PatrickChua: Change the combobox options in RunbaseBatch class Blog bot DAX Blogs 0 28.10.2006 18:14
Часовой пояс GMT +3, время: 12:10.
