Старый 30.05.2008, 18:05   #1
Ruslan Goncharov: Stereogram in AX
Источник: http://rusgon.blogspot.com/2008/05/s...ram-in-ax.html
Following job demonstrates random dot stereogram technique in AX.static void RDStechniqueJob(Args _args){ #define.image("C:\Images\pattern.bmp") #define.imageSizeX(300) // width*2 #define.imageSizeY(300) // height #define.depth(5) Form form; FormRun formRun; FormDesign formDesign; Args args; FormBuildDesign formBuildDesign; FormBuildWindowControl formBuildWindowControl; FormWindowControl pane; Image image = new Image(); Image pattern = new Image(); int _x, _y; void Draw() { Random rnd = new Random(); int color; ; for(_x=0; _x<span class="sy0">
Ruslan Goncharov: From Microsoft Dynamics AX Programming newsgroup tricks Blog bot DAX Blogs 0 24.05.2008 00:08
Ruslan Goncharov: Scrolling in AX 3.0 without dll Blog bot DAX Blogs 0 09.03.2008 23:20
Ruslan Goncharov: How to clarify what happened with variables in AX Blog bot DAX Blogs 0 17.01.2008 15:40
Ruslan Goncharov: How to get the screenshots of all open windows in AX Blog bot DAX Blogs 0 12.01.2008 12:31
Ruslan Goncharov: How to add a document into AX programmically? (Document handling) Blog bot DAX Blogs 0 29.12.2007 19:50
Часовой пояс GMT +3, время: 22:59.
