Старый 17.07.2008, 06:16   #1
Universal Field Changer (xpo project)
Источник: http://alexvoy.blogspot.com/2008/07/...o-project.html
Sometimes we need to change the values of a group of records in a table at once. I hope this project will be useful in this meaning.
It allows you to choose a table with excluding some of them. After that you can browse the table and open it directly in AOT.
You then can choose a field from the table excluding or not system fields and look through existing values to pick up or just input a new value.
Change function works only with a result of the query which text you can see as well. No checks nor validatings!
Use it at your own risk and do not forget how it can be dangerous for the system to change their fields directly!
The project comprises three temporary tables and one form. Tested on version 4.0.
Next, I am going to implement it as a class.
axaptapedia: Create New AOT Project From Template Blog bot DAX Blogs 0 29.08.2008 21:10
Class Universal Field Changer (xpo project) Blog bot DAX Blogs 0 05.08.2008 05:18
Dynamics AX: Dynamics AX project success - Customer Ownership & Expectations Blog bot DAX Blogs 0 07.08.2007 21:10
Dynamics AX: To-Increase Project Center Blog bot DAX Blogs 0 27.07.2007 17:30
Ещё книга про Ax на английском - Inside Microsoft Dynamics AX 4.0 StasD DAX: База знаний и проекты 36 22.03.2007 12:51
Часовой пояс GMT +3, время: 04:16.
