Старый 21.07.2008, 03:39   #1
axaptapedia: Progress Bar
Источник: http://www.axaptapedia.com/Progress_Bar
Summary: /* Introduction */
<div>== Introduction ==
A progress bar is a graphical representation of a job's progress and they are used extensively in the application. If a long running process displays a progress bar, the user can monitor the progress and can estimate the approximate time of completion. It is best practice to always display a progress bar during a lengthy process.
== Progress Bar within a batchable class ==
The RunBase framework has methods which will initialize the progress bar so that you can focus on coding the process.
// progress bar Runbase demo
public void run()
str text;
int percent;
int counter;
int64 progressTotal = 200; // hard coded for demo purpose (this is normally calculated)
this.progressInit("Processing", progressTotal, #AviFormLetter);
progress.setText("Item");
for (counter = 1; counter
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 04.04.2009 22:05
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 31.03.2009 06:06
axaptapedia: Progress Bar Blog bot DAX Blogs 0 27.06.2008 11:05
axaptapedia: Configuration in title bar Blog bot DAX Blogs 1 08.03.2007 19:57
Как правильно работать с Progress bar? malex DAX: Программирование 2 19.09.2004 23:23
Часовой пояс GMT +3, время: 13:24.
