Старый 05.08.2008, 12:05   #1
C# and AX Development: Running batch jobs automatically in Dynamics AX
Источник: http://olondono.blogspot.com/2008/08...ically-in.html
For learning how to create and launch batch jobs in Dynamics AX, please take a look to all topics in http://msdn.microsoft.com/en-us/libr...82(AX.10).aspx.
If we want to configure an automatic batch job server, we need to modify the class SysStartupCmdBatchRun, method infoRun, as follows:
void infoRun() { batchRun batchRun = new batchRun(); ; batchRun.parmUseForm(true); batchRun.parmGroupId(parm); // added batchRun.run(); }
And for a batch group named "myGroup" for example, we can use the Microsoft Dynamics AX Configuration Utility to specify the "Command to run at application startup:" as Batch_myGroup. This enable the AX client to run every batch job in this group.
We can also use the command line as {path}\ax32.exe startupcmd=batch_myGroup.
Часовой пояс GMT +3, время: 11:05.
