Старый 23.12.2008, 22:05   #1
Microsoft Dynamics CRM Team Blog: Update Rollup 1 for Microsoft Dynamics CRM 4.0
Источник: http://blogs.msdn.com/crm/archive/20...s-crm-4-0.aspx
The Microsoft Dynamics CRM Sustained Engineering team released Microsoft Dynamics CRM 4.0 Update Rollup 1 on Monday, November 24, 2008.
Below is the link to the release and information on how to deploy it to your clients via AutoUpdate. Please see the Knowledge Base (KB) article for more details about the Update Rollup 1 content and instructions. The Update Rollup 1 client can be deployed before the server is upgraded to Update Rollup 1.
Making Update Rollup 1 available to your clients via AutoUpdate:
You can find more information about AutoUpdate in Eric Newell’s blog entry at http://blogs.msdn.com/crm/archive/20...utoupdate.aspx.
If you have a direct internet connection from your client machines, you can avoid some of the configuration steps and use the linkID directly. Below are the necessary steps to configure the AutoUpdate for Update Rollup 1.
Note: These are steps 5, 6 and 7 of Eric’s blog.
1. Create the configuration XML file and save it.
          {9D28D100-595D-4CC4-AE00-6A90913B968D}
          Update Rollup 1 for Microsoft Dynamics CRM 4.0 (KB 952858)
          true
          true
          OutlookLaptop, OutlookDesktop
          136466
2. From the command prompt, go to the directory where the ClientPatchConfigurator.exe is located ([ServerInstallDir]\Tools and type microsoft.crm.tools.clientpatchconfigurator.exe [configfile].xml
3. Once the patch has been uploaded, launch the Outlook client
The dialog should now appear saying that “Update Rollup 1 for Microsoft Dynamics CRM 4.0 (KB 952858” is available. If the is set to false, the client will only see the update if the user selects “Check for Updates” via the CRM Menu in the Outlook client.
Happy Holidays!
Matt Brown
Microsoft Dynamics CRM Team Blog: Update Rollup 3 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 14.03.2009 07:10
Microsoft Dynamics CRM Team Blog: Update Rollup 2 for Microsoft Dynamics CRM 4.0 - More Info Blog bot Dynamics CRM: Blogs 0 12.02.2009 13:05
Microsoft Dynamics CRM Team Blog: Update Rollup 2 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 20.01.2009 21:05
Часовой пояс GMT +3, время: 00:34.
