#1 |
mscrm4ever: Change Cases Associated Default View
Источник: http://mscrm4ever.blogspot.com/2008/...ault-view.html
============== This is a complementary post to the “Changing Activity / History Default View”. The code sample uses exactly the same concept as the former post so if you’re using that then you should integrate both solution to avoid duplicate functions. //Case History statecode options var ServiceOptions = { Active : "0", Resolved : "1", Canceled : "2", All : "All" } var _loadarea = loadArea; loadArea = function(areaid) { //load the iframe _loadarea(areaid); if( areaid != "areaService" ) return; //create the iframe object var iframe = document.getElementById(areaid + "Frame"); //wait until the iframe is fully loaded ("complete") iframe.onreadystatechange = function() { if( iframe.readyState == "complete") { var picklist,option; //reference to the iframe document var iframeDoc = iframe.contentWindow.document; switch(areaid) { case "areaService": picklist = iframeDoc.all.statecode[0]; option = ServiceOptions.All; break; } picklist.value = option; picklist.FireOnChange(); } } } Источник: http://mscrm4ever.blogspot.com/2008/...ault-view.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
