Старый 13.01.2009, 20:05   #1
gatesasbait: Exception::Break in while loop
Источник: http://gatesasbait.spaces.live.com/B...B9F5!290.entry
Good morning
I noticed something interesting yesterday. When breaking execution while running a loop (by pressing ctrl-break) an Exception::Break is thrown if 'Yes' is clicked on the resulting break prompt. Sometimes even if the exception is caught, the execution stops, other times it will continue with no apparent reason. Here's the example:
public static void whileBreak(Args _args)
    int i = 1;
    #define.dosomething(i++; i--;)
    while (i < 1000000)
        try
            i++;
            #dosomething
            sleep(50);
            #dosomething
        catch (Exception::Break)
            info("Break caught.");
If we want to be sure the execution will stop, we need to add another 'throw' inside the 'catch' statement. Also note that adding any breakpoint seem to change the behavior of the try-catch.
Issues concerning X++: Exception handling and transactions Blog bot DAX Blogs 1 14.02.2009 00:46
gatesasbait: AP Posting fails because of security setup in Dynamics Ax 4 Blog bot DAX Blogs 0 03.02.2009 02:07
gatesasbait: How to temporarily suppress infolog messages in Dynamics Ax (deux) Blog bot DAX Blogs 7 28.01.2009 17:45
axaptapedia: Exception handling Blog bot DAX Blogs 0 24.06.2008 18:05
gatesasbait: Forcing specific layers to compare in Ax 4.0x Blog bot DAX Blogs 0 18.12.2007 19:50
Часовой пояс GMT +3, время: 01:29.
