Старый 17.03.2009, 01:05   #1
Customized Comment In Your Code Editor
Источник: http://alexvoy.blogspot.com/2009/03/...de-editor.html
Standard code editor allows to create your own kind of comments. Generally, a style of comments depends on your programming style and the company's policies on that.
I prefer to frame changes I make in a code with parentheses in the following style:
// Voytsekhovskiy, Alexey (My company name) (2009/03/16) (#)
the code as it wasd before my changes
//</span>
// Your code here as it was before
<span class="rem">// //
Dynamics Mobile: How to code your own barcode enabled tasklets (Motorola and Intermec devices) Blog bot DAX Blogs 1 03.06.2014 06:34
Kashperuk Ivan: Tool for protecting your Dynamics AX source code Blog bot DAX Blogs 0 12.12.2008 04:07
axaptapedia: Code editor Blog bot DAX Blogs 0 10.10.2007 22:52
casperkamal: Using Editor Scripts Blog bot DAX Blogs 0 20.12.2006 12:50
Часовой пояс GMT +3, время: 02:35.
