Старый 26.05.2009, 01:10   #1
25,644 / 848 (80) +++++++
palleagermark: formdatasource.research(TRUE)
Источник: http://palleagermark.blogspot.com/20...earchtrue.html
A small but not uninteresting little parameter has sneaked its way into AX 2009. The research method on form data sources now allows you to make AX reposition the cursor to the active record you were placed on when calling research.
To do this, call xxx_ds.research(true).
This little parameter saves you the effort of saving data for the record you are on, and use the saved data with the find() method to find the record again, and hopefully (I haven’t tested this though) it has much better performance than the find method. Performance couldn't really be worse than with the find method, so I assume performance is much better when MS introduces this as a new parameter.
Link to MSDN SDK documentation for the method: http://msdn.microsoft.com/en-us/library/aa597768.aspx
palleagermark: Bug in EP 2009 when having the debug flag set to true Blog bot DAX Blogs 0 05.01.2009 11:06
Dynamics AX: AMR Research: Awakening a Sleeping Giant - Inside Microsoft Business Solutions' ERP Strategy Blog bot DAX Blogs 0 22.09.2008 22:05
Метод prev() класса FormDataSource всегда возвращает True Morpheus DAX: Программирование 3 08.09.2006 11:13
Различные типы связей (LinkType) для FormDataSource Maxim Gorbunov DAX: База знаний и проекты 1 16.05.2004 13:20
Гибрид FormTableControl и FormDataSource Андре DAX: Программирование 27 01.10.2003 09:58
Часовой пояс GMT +3, время: 06:40.
