Старый 20.06.2009, 19:05   #1
Arijit Basu: Intelligent Data Management Framework for Microsoft Dynamics AX
Источник: http://daxguy.blogspot.com/2009/06/i...framework.html
The Intelligent Data Management Framework for Microsoft Dynamics® AX helps administrators optimize Dynamics AX database layout by intelligently monitoring index usage, index layout, fragmentation and query patterns thru indices. The framework allows reduction of the database size by purging transaction records from a set of related entities, while maintaining the consistency and integrity of production data. The Intelligent Data Management Framework provides customers and partners the ability to identify and discover related entities based on Microsoft Dynamics AX metadata and to determine the purging criteria for entities and transactions. The Intelligent Data Management Framework also analyzes the production database to determine current usage patterns and assesses the health of the Microsoft Dynamics AX application.
At RTM, this Framework will include “Archive to Offline” Instance Support.
Click here to download [ Requires Partnersource Access]
ax2009, ax3.0, ax4.0, idmf, intelligent data management, администрирование, архивирование, база данных, инструменты
Arijit Basu: Demo Data for Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 09.07.2008 02:10
Arijit Basu: Credit Card Import Transformation Sample for Expense Management in Microsoft Dynamics AX 5.0 Blog bot DAX Blogs 0 12.02.2008 15:10
Arijit Basu: PerformancePoint Server 2007 Tool: Data Import Wizard for Microsoft Dynamics AX Blog bot DAX Blogs 0 22.01.2008 21:33
Arijit Basu: Optimizing Data Upgrade for Microsoft Dynamics AX 4.0 and 4.0 Service Pack on Microsoft SQL Server Blog bot DAX Blogs 1 10.01.2008 12:06
Часовой пояс GMT +3, время: 07:54.
