Старый 07.07.2009, 03:05   #1
Dynamics AX Sustained Engineering: Upgrade script ReleaseUpdateDB41_Invent\updateInventItemPrice () fails without LogisticsAdvanced license code
Источник: http://blogs.technet.com/dynamicsaxs...ense-code.aspx
During upgrade from Axapta 3.0 to Dynamics AX 4.0 or AX 2009, upgrade script ReleaseUpdateDB41_Invent\updateInventItemPrice () fails in the absence of LogisticsAdvanced license code. License codes are used to enable configuration keys. Absence of LogisticsAdvanced license codes cause the disabling of the LogisticsAdvanced configuration key, which, in turn, removes the InventDimCombination Table from the database. This results in the upgrade script ReleaseUpdateDB41_Invent\updateInventItemPrice () failing.
The fix is to add a configuration key validation before processing table InventDimCombination, in \Classes\ReleaseUpdateDB41_Invent\updateInventItemPrice ()
public void updateInventItemPrice()
CostingVersion costingVersion;
InventItemPrice inventItemPrice;
InventItemPrice inventItemPriceExist;
InventTableModule inventTableModule;
InventDimCombination inventDimCombination;
CostingVersionId costingVersionId = #commonCostingVersionId;
InventDimId inventDimId = InventDim::inventDimIdBlank();
InventTable inventTable;
int rowCount = 0;
SkipAOSValidationPermission skipAOS;
void insertInventItemPrice(
CostingVersionId _costingVersionId,
ModuleInventPurchSales _moduleInventPurchSales,
CostingVersionPriceType _priceType,
ItemCostModel _itemCostModel,
boolean _restrictItemCostModel,
ItemPurchModel _itemPurchModel,
boolean _restrictItemPurchModel,
InventItemCostingType _costingType
insert_recordset inventItemPrice (VersionId, ItemId, Price, PriceUnit, PriceQty, Markup, PriceAllocateMarkup, UnitID, PriceType, ActivationDate, InventDimId, CostingType)
select _costingVersionId, ItemId, Price, PriceUnit, PriceQty, Markup, AllocateMarkup, UnitId, _priceType, PriceDate, inventDimId, _costingType from inventTableModule
where inventTableModule.ModuleType == _moduleInventPurchSales
&& inventTableModule.Price != 0
&& inventTableModule.PriceDate != dateNull()
exists join inventTable
where inventTable.ItemDimCostPrice == NoYes::No
&& inventTable.ItemId == inventTableModule.ItemId
&& (inventTable.CostModel == _itemCostModel || !_restrictItemCostModel)
&& (inventTable.PurchModel == _itemPurchModel || !_restrictItemPurchModel)
notexists join inventItemPriceExist
where inventItemPriceExist.ItemId == inventTableModule.ItemId
&& inventItemPriceExist.InventDimId == InventDim::inventDimIdBlank()
&& inventItemPriceExist.PriceType == _priceType
&& inventItemPriceExist.ActivationDate == inventTableModule.PriceDate;
rowCount += inventItemPrice.RowCount();
void insertInventItemPriceDimSalesPurchase(
insert_recordset inventItemPrice (VersionId, UnitID, ItemId, Price, PriceUnit, PriceQty, Markup, PriceAllocateMarkup, PriceType, ActivationDate, CostingType, InventDimId)
select _costingVersionId, UnitId, ItemId, Price, PriceUnit, PriceQty, Markup, AllocateMarkup, _priceType, PriceDate, _costingType from inventTableModule
join InventDimId from inventDimCombination
where inventDimCombination.ItemId == inventTableModule.ItemId
where inventTable.ItemDimCostPrice == NoYes::Yes
&& inventItemPriceExist.InventDimId == inventDimCombination.InventDimId
void insertInventItemPriceDimCost(
ModuleInventPurchSales moduleInventPurchSales;
CostingVersionPriceType priceType;
moduleInventPurchSales = ModuleInventPurchSales::Invent;
priceType = CostingVersionPriceType::Cost;
insert_recordset inventItemPrice (VersionId, UnitID, ItemId, ActivationDate, CostingType, PriceType, InventDimId, Price, PriceUnit, PriceQty, Markup, PriceAllocateMarkup)
select _costingVersionId, UnitId, ItemId, PriceDate, _costingType, priceType from inventTableModule
where inventTableModule.ModuleType == moduleInventPurchSales
join InventDimId, del_CostPrice, del_PriceUnit, del_PriceQty, del_Markup, del_AllocateMarkup from inventDimCombination
&& (inventTable.CostModel == _itemCostModel)
&& inventItemPriceExist.PriceType == priceType
this.tableProgress(tablenum(InventItemPrice));
skipAOS = new SkipAOSValidationPermission();
skipAOS.assert();
// BP deviation documented
inventItemPrice.skipAosValidation(true);
inventItemPrice.skipDataMethods(true);
inventItemPrice.skipEvents(true);
ttsbegin;
// creating a common costing version
costingVersion = CostingVersion::find(#commonCostingVersionId, true);
if (!costingVersion)
costingVersion.VersionId = #commonCostingVersionId;
costingVersion.Blocked = NoYesCombo::Yes;
costingVersion.BlockActivation = NoYesCombo::Yes;
costingVersion.CostingType = CostingVersionCostingType::Normal;
// copy records from InventTableModule to InventItemPrice
// copy cost prices
insertInventItemPrice(#commonCostingVersionId, ModuleInventPurchSales::Invent, CostingVersionPriceType::Cost, NoYes::No, NoYes::Yes, NoYes::No, NoYes::No, InventItemCostingType::Undefined);
insertInventItemPrice('', ModuleInventPurchSales::Invent, CostingVersionPriceType::Cost, NoYes::Yes, NoYes::Yes, NoYes::No, NoYes::No, InventItemCostingType::Last);
// copy purchase prices
insertInventItemPrice(#commonCostingVersionId, ModuleInventPurchSales::Purch, CostingVersionPriceType::Purch, NoYes::No, NoYes::No, NoYes::No, NoYes::Yes, InventItemCostingType::Undefined);
insertInventItemPrice('', ModuleInventPurchSales::Purch, CostingVersionPriceType::Purch, NoYes::No, NoYes::No, NoYes::Yes, NoYes::Yes, InventItemCostingType::Last);
// copy sales prices
insertInventItemPrice(#commonCostingVersionId, ModuleInventPurchSales::Sales, CostingVersionPriceType::Sales, NoYes::No, NoYes::No, NoYes::No, NoYes::No, InventItemCostingType::Undefined);
if(new DictConfigurationKey(new DictTable(tablenum(InventDimCombination)).configurationKeyId()).enabled())
// copy records from InventDimCombination to InventItemPrice
// copy cost prices
insertInventItemPriceDimCost(#commonCostingVersionId, NoYes::No, InventItemCostingType::Undefined);
insertInventItemPriceDimCost('', NoYes::Yes, InventItemCostingType::Last);
// copy purcahse prices
insertInventItemPriceDimSalesPurchase(#commonCostingVersionId, ModuleInventPurchSales::Purch, CostingVersionPriceType::Purch, NoYes::No, NoYes::Yes, InventItemCostingType::Undefined);
insertInventItemPriceDimSalesPurchase('', ModuleInventPurchSales::Purch, CostingVersionPriceType::Purch, NoYes::Yes, NoYes::Yes, InventItemCostingType::Last);
insertInventItemPriceDimSalesPurchase(#commonCostingVersionId, ModuleInventPurchSales::Sales, CostingVersionPriceType::Sales, NoYes::No, NoYes::No, InventItemCostingType::Undefined);
// copy cost prices
if (rowCount)
costingVersion.LastUpdate = systemdateget();
costingVersion.write();
ttscommit;
aEremenko: Последние изменения в списке совместимости для AX Blog bot DAX Blogs 7 05.06.2009 05:10
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
AX UK: Microsoft Dynamics AX 3.0 to 2009 Data and Code Upgrade Training Blog bot DAX Blogs 1 03.02.2009 11:15
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Часовой пояс GMT +3, время: 23:20.
