Старый 02.09.2009, 16:05   #1
Everything AX: How to quickly get table row counts in Axapta
Источник: http://www.crankturner.com/2008/09/h...counts-in.html
Our Dynamics AX database is getting bigger - that means business is active and that is usually a good thing :) We use SQLServer as the back-end database server. Here is a trick that will count all of the rows in all of the Axapta tables in about 1 second. This trick will only run on SQLServer (all versions 2000 - 2008).
Here is a query that will return the row counts of every table in your Dynamics AX database.
<blockquote> USE Axapta
go
<font face="Courier">
select so.name as Table_Name
      ,rows
  from sysindexes si
         inner join
       sysobjects so
         on si.id = so.id
where so.type = 'u'
   and indid
gatesasbait: "Go to the Main Table Form" differences between Axapta 2.x and Dynamics AX 4 Blog bot DAX Blogs 0 12.08.2008 19:05
Ruslan Goncharov: How to get the screenshots of all open windows in AX Blog bot DAX Blogs 0 12.01.2008 12:31
C# and AX Development: How to delete AOT objects (AX/Axapta) Blog bot DAX Blogs 0 13.12.2007 19:50
Часовой пояс GMT +3, время: 05:12.
