Старый 02.10.2009, 05:14   #1
crmdude: SetStateDynamicEntity on Incident Entity
Источник: http://crmdude.wordpress.com/2009/10...cident-entity/
I wrote a plug-in that needs to perform some validation when a user tries to close an Incident record in CRM and verify whether it can be closed or not. I registered it against the SetStateDynamicEntity, however it didn’t trigger. I then registered it against the Create of the IncidentClose entity, but it didn’t trigger there either (probably because I registered in the parent pipleine rather than the child). I then realised there is a Close message and registered against that instead, and it worked!
The SetStateDynamicEntity message is only triggered when an Incident is re-activated after being closed.
crmdude: Modifying Views outside Microsoft CRM Blog bot Dynamics CRM: Blogs 0 28.09.2009 03:14
crmdude: xRM Video on YouTube Blog bot Dynamics CRM: Blogs 0 14.09.2009 11:05
crmdude: Querying a PartyList field Blog bot Dynamics CRM: Blogs 0 14.09.2009 11:05
Часовой пояс GMT +3, время: 05:42.
