Старый 14.10.2009, 09:05   #1
CRM DE LA CREME! CRM 4.0 System Requirements and Required Components
Источник: http://crmdelacreme.blogspot.com/200...-required.html
Microsoft Dynamics CRM requires several software applications and components that work together to create an effective system. Before you install Microsoft Dynamics CRM, use this section for guidance to verify that system requirements are met and the necessary software components are available.
Unless specified otherwise, Microsoft Dynamics CRM supports the latest version and service pack (SP) for all required components, such as Windows Server, SQL Server, Internet Explorer, and Exchange Server.
For the most up-to-date information about system requirements and required components, see the
Microsoft Dynamics CRM 4.0 Server Readme.
For more information, see:
Microsoft Dynamics CRM Server hardware requirements
Microsoft Dynamics CRM Server software requirements
Microsoft Dynamics CRM Connector for SQL Server Reporting Services
Microsoft Dynamics CRM E-mail Router software requirements
Microsoft Dynamics CRM for Outlook hardware requirements
Microsoft Dynamics CRM for Outlook software requirements
Microsoft Dynamics CRM Web client software requirements
Microsoft Dynamics CRM Data Migration Manager hardware requirements
Data Migration Manager software requirements
64-bit supported configurations
Language support
Currency support
Microsoft Dynamics CRM Team Blog: Data Design for CRM Projects - Customisation Approaches Blog bot Dynamics CRM: Blogs 0 22.05.2009 07:05
Microsoft Dynamics CRM Team Blog: Customizing Microsoft Dynamics CRM 4.0 for High-Latency and Low-Bandwidth Environments Blog bot Dynamics CRM: Blogs 0 16.05.2009 04:40
Jim Wang: Customizing CRM by Using the Microsoft Dynamics CRM Developer Toolkit Blog bot Dynamics CRM: Blogs 0 09.04.2009 22:05
Microsoft Dynamics CRM Team Blog: Are You Certifiable? Blog bot Dynamics CRM: Blogs 0 24.07.2008 01:05
Dynamics AX: Dynamics AX 2009 System Requirements Blog bot DAX Blogs 0 12.06.2008 11:05
Часовой пояс GMT +3, время: 01:27.
