Старый 18.10.2009, 20:05   #1
gustafwesterlund: Create replacement entities
Источник: http://gustafwesterlund.blogspot.com...-entities.html
Sometimes, using a standard entity like product or invoice might not be the most optimal choice. Often due to the fact that there is quite a lot of business logic built into these entities. Therefore it is somtimes better to create you own entity instead. However, if you try to create a new entity with the name "Product" you will notice that it cannot be done since there already is an entity with that displayname.
The solution is quite simple, change the displayname of the built in product to "Old product" and remove all rights for all users to it and it will disapear for all normal users. You can then create your new entity with the displayname "Product".
Gustaf Westerlund
Microsoft Dynamics CRM Architect
Logica
www.logica.com
Microsoft Dynamics CRM Team Blog: The CRM Configurator’s Dilemma: Repurpose or Create? Blog bot Dynamics CRM: Blogs 0 18.09.2009 03:13
gustafwesterlund: Workflow scope and security roles Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Microsoft Dynamics CRM Team Blog: Data Design for CRM Projects - Customisation Approaches Blog bot Dynamics CRM: Blogs 0 22.05.2009 07:05
использование create() ds sassas DAX: Программирование 5 11.11.2004 15:22
Часовой пояс GMT +3, время: 16:58.
