Старый 03.12.2009, 19:05   #1
Dynamics AX Sustained Engineering: Item template detail will be deleted if the item is deleted
Источник: http://blogs.technet.com/dynamicsaxs...s-deleted.aspx
If the original item in the Inventory Table is deleted, then the records in the tables, with itemID field, will also be deleted. Since this is a general issue for the record templates feature in Ax, and is caused by the fact that deleting templates is not supported, SE’s recommendation for solving this issue is as below.
This fix is applied in \Classes\SysRecordTemplate:initValue().
Change:
if (common.TableId == tablenum(EventRuleData))
excludeValidateField.add(fieldId2Ext(fieldnum(EventRuleData,RuleId),1));
To:
switch(common.TableId)
case tablenum(EventRuleData):
break;
case tablenum(InventTableModule):
excludeValidateField.add(fieldId2Ext(fieldnum(InventTableModule,ItemID),1));
break;
case tablenum(InventItemLocation):
excludeValidateField.add(fieldId2Ext(fieldnum(InventItemLocation,ItemID),1));
break;
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
aEremenko: Последние изменения в списке совместимости для AX Blog bot DAX Blogs 7 05.06.2009 05:10
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Часовой пояс GMT +3, время: 02:26.
