Старый 04.12.2009, 02:05   #1
emeadaxsupport: Error access SSRS reports - System.Web.Configuration.RegexWorker threw an exception
Источник: http://blogs.msdn.com/emeadaxsupport...exception.aspx
Lately we run into following problem: when navigating to any SSRS report via Enterprise portal or even by the SSRS report manager site, the following error is displayed where the report should appear:
An error has occurred during report processing. (rsProcessingAborted). The type initializer for 'System.Web.Configuration.RegexWorker' threw an exception.
The cause of the issue is that permissions for:
  • for SQL 2005 the account running the IIS application pool for Report Manager (should be bc proxy account)
  • for SQL 2008 the account running SSRS (should be bc proxy account)
are incorrect.
Granting admin rights to the accounts involved and then restarting IIS (or stopping starting the SQL 2008 SSRS process) can quickly prove whether you have a permissions issue. If it works with admin rights then you can remove the admin rights and make sure the accounts have permission to use DLLs in the GAC (typically C:\windows\assembly). You can verify exactly which DLL needs permission by checking the full error log at:
  • C:\Program Files\Microsoft SQL Server\MSSQL.3\Reporting Services\LogFiles for SQL 2005 Reporting Services
  • C:\Program File\Microsoft SQL Server\MSRS10\Reporting Services\LogFiles for SQL 2008 Reporting Services
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 02:07.
