Старый 09.12.2009, 09:05   #1
Dynamics AX Sustained Engineering: Incorrect posting profile used when cancelling a prepayment
Источник: http://blogs.technet.com/dynamicsaxs...repayment.aspx
Prepayment reversal is posted using the default posting profile summary account and then eventually reversed to the prepayment posting profile summary account. When cancelling a payment unnecessary reversal transaction records are inserted in the CustTrans table. These transactions should be at least marked/checked in the ‘CancelledPayment’ column.
This fix is applied in \Classes\CustVendSettle_Cust\postingProfileSettle().
Change:
custVoucher.parmTransVoucher(_custVendTrans.Voucher);
custVoucher.parmVoucher(_custVendTrans.Voucher);
custVoucher.parmInvoiceId(_custVendTrans.Invoice);
custVoucher.parmPaymMode(_custVendTrans.PaymMode);
custVoucher.parmPaymSpec(_custVendTrans.PaymSpec);
custVoucher.parmFormLetter(_custVendTrans.Voucher);
To:
cust.Voucher.parmCancelledPayment(true);
Dynamics AX Sustained Engineering: New Compatibility Testing Results - October 2009 Blog bot DAX Blogs 0 12.10.2009 20:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Часовой пояс GMT +3, время: 15:30.
