Старый 14.12.2009, 14:05   #1
emeadaxsupport: How to run a form modal
Источник: http://blogs.msdn.com/emeadaxsupport...orm-modal.aspx
We wanted to ensure that when using a particular form in AX2009 client no other forms/reports are accessible until the form is closed.
For this we need to make the form a modal form.
We have an example of this in the standard application which can be copied, look at: Classes\SysModalFormDisableAllWkspcs.
This is used to make the Organize favourites form in AX modal (the name of that one is SysFavoritesOrganizeFavorites).
The way we achieve it is by starting the form like this:
modalForm.init();
modalForm.run();
If (!modalForm.closed())
modalForm.wait(true);
emeadaxsupport: How to fix SQL error: "Too many parameters were provided in this RPC request" Blog bot DAX Blogs 0 01.09.2009 15:05
emeadaxsupport: How to open an AX form from your own help Blog bot DAX Blogs 0 26.07.2009 15:07
How To Resrtict Form Setup Conext Menu Item Blog bot DAX Blogs 0 01.05.2009 04:13
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
Часовой пояс GMT +3, время: 19:47.
