Старый 22.01.2010, 15:05   #1
palleagermark: Create a 64-bit encoded string from an image in AX
Источник: http://palleagermark.blogspot.com/20...rom-image.html
Here's how you can create a 64-bit encoded string from an image in AX:
static void Job4(Args _args)
System.Drawing.Image image;
Str string;
System.Byte[] byteArray;
System.IO.MemoryStream memoryStream;
// Load the file
image = System.Drawing.Image::FromFile(@"C:\sandbox\test.tif");
// Convert the file to a byte array
memoryStream = new System.IO.MemoryStream();
image.Save(memoryStream, System.Drawing.Imaging.ImageFormat::get_Tiff());
// Create the 64-bit encoded string
string = System.Convert::ToBase64String(memoryStream.ToArray());
// Save it again, to a new image (just for fun or test of you want)
AifUtil::saveBase64ToFile(@"C:\sandbox\test1.tif", string);
mfp: New X++ Editor Blog bot DAX Blogs 2 06.01.2010 02:06
palleagermark: Creating an image file based on plain text from AX Blog bot DAX Blogs 0 03.03.2009 03:08
palleagermark: Channel 9 video: Dynamics AX Version Control interview from Convergence in Copenhagen 2008 Blog bot DAX Blogs 0 30.01.2009 16:05
Microsoft Dynamics CRM Team Blog: 32-bit vs. 64-bit CRM SDK Assemblies Blog bot Dynamics CRM: Blogs 0 11.09.2008 20:05
Часовой пояс GMT +3, время: 17:41.
