Старый 30.01.2010, 00:05   #1
mfp: Optional parameters in C# and X++
Источник: http://blogs.msdn.com/mfp/archive/20...n-c-and-x.aspx
In the upcoming 4.0 version of C# the language now supports optional parameters – just like X++. The following is a valid method declaration in both languages:
public void foo(int parameter1, int parameter2 = 0, int parameter3 = 100)
There are a few differences between the languages with regards to optional parameters:
Named parameters
In X++ you can only omit optional parameters starting from the last parameter. C# makes it possible to omit any optional parameter. For example:
foo(5, parameter3: 1000)
will call foo(5, 0, 1000).
prmIsDefault
C# doesn’t provide a way to determine, if a parameter was omitted by the caller, or the caller passed in a value identical to the default value. In X++ the prmIsDefault() method can be used to determine this. However, the use cases for this method are rare – and often fragile. For example, consider this X++ class:
class BaseClass
    int value;
    public void init(int _value = 0)
        if (prmIsDefault(value))
            value = /* some complex calculation */
        else
            value = _value;
Now someone comes along and extends the class: class MyClass extends BaseClass
    str myStr;
        myStr = 'foo';
        super(_value);
Can you see the problem? This following code will never call the complex calculation (which probably was the intention): MyClass myClass = new MyClass();
To solve the problem MyClass needs to be implemented as:
    str myStr;
        myStr = 'foo';
        if (prmIsDefault(_value))
            super();
        else
            super(_value);
Which really is terrible, as the implementation of the derived class depends on the implementation of the base class. This is bound to break eventually. Add a few more optional parameters and a few more levels of depth in the class hierarchy, and you'll have a real nightmare. My recommendation is to only use prmIsDefault() in private methods - as they can't be overridden. In C# you can easy live without this method, as you can achieve the same in a more robust manner using method overloading:
class BaseClass
    int value;
    public void init()
        int _value = /* some complex calculation */
        new(_value);
    public void init(int _value)
        value = _value;
It is a good thing we solved the dangling semicolon issue – otherwise it would haunt the C# community in a not too distant future.
Часовой пояс GMT +3, время: 21:08.
