Старый 05.02.2010, 01:05   #1
CRM Programmer: Get Picklist Value By Picklist Name
Источник: http://crmpro.blogspot.com/2010/02/g...list-name.html
I wrote some method to get picklist value by knowing picklist name.
namespace test
public class CrmServiceProvider
private WebMetadataService.MetadataService _MetaService = null;
///* Create a MetadataService end point */
private WebMetadataService.MetadataService MetaService
get
if (_MetaService == null)
_MetaService = new WebMetadataService.MetadataService();
_MetaService.Url = "http://localhost/mscrmservices/2007/metadataservice.asmx";
// Use a special user credentials
NetworkCredential cred = new NetworkCredential();
cred.Domain = ConfigurationManager.AppSettings["Domain"];
cred.UserName = ConfigurationManager.AppSettings["UserName"];
cred.Password = ConfigurationManager.AppSettings["PassWord"];
_MetaService.UseDefaultCredentials = false;
_MetaService.Credentials = cred;
_MetaService.UnsafeAuthenticatedConnectionSharing = true;
WebMetadataService.CrmAuthenticationToken token = new WebMetadataService.CrmAuthenticationToken();
token.AuthenticationType = 0;
token.OrganizationName = ConfigurationManager.AppSettings["Organization"];
_MetaService.CrmAuthenticationTokenValue = token;
return _MetaService;
public int GetPicklistValueByPicklistName(string PicklistName, string EntityLogicalName, string LogicalName)
int retval = -1;
/* Retrieve the attribute metadata */
WebMetadataService.RetrieveAttributeRequest attributeRequest = new WebMetadataService.RetrieveAttributeRequest();
attributeRequest.EntityLogicalName = EntityLogicalName;
attributeRequest.LogicalName = LogicalName; //picklist
WebMetadataService.RetrieveAttributeResponse attributeResponse =
(WebMetadataService.RetrieveAttributeResponse)MetaService.Execute(attributeRequest);
/* Cast the attribute metadata to a picklist metadata */
WebMetadataService.PicklistAttributeMetadata picklist =
(WebMetadataService.PicklistAttributeMetadata)attributeResponse.AttributeMetadata;
foreach (WebMetadataService.Option op in picklist.Options)
if (op.Label.UserLocLabel.Label == PicklistName)
retval = op.Value.Value;
return retval;
To call this method use then next construction:
int psv = GetPicklistValueByPaymentSystemName(categorycode, "account", "accountcategorycode");
if (psv > 0)
acc.accountcategorycode = new Picklist();
acc.accountcategorycode.Value = psv;
Старый 05.02.2010, 13:17   #2
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Неплохой пример работы с метаданными.
Jim Wang: Get Entity/Attribute's Display Name from CRM database Blog bot Dynamics CRM: Blogs 0 28.03.2009 01:05
Часовой пояс GMT +3, время: 03:01.
