Старый 01.03.2010, 16:05   #1
25,644 / 848 (80) +++++++
gustafwesterlund: Reporting Services Windows Service wouldn't start
Источник: http://gustafwesterlund.blogspot.com...s-service.html
I created a new differencing disk of a CRM virtual machine today and I had some troubles getting Reporting services up and running. The service simply wouldn't start. I had previously used the same virtual harddisk base for other systems so I found it a bit strange, it should work.
When I looked in the event viewer it showed the error "Report Server (MSSQLSERVER) cannot connect to the report server database.".
I looked around a bit on the net and found a reference to the following which helped:
http://support.microsoft.com/kb/839803
I concernings increasing the timeouts of pipes in the system to 60 seconds instead of 30. This might be needed on VPC:s that are not so fast and might not get the service up and running fast enough.
Gustaf Westerlund
Microsoft Dynamics CRM Chief Architect
Logica
www.logica.com
DAX2009, требует SQL 2005 Reporting Services Service Pack 2 slava09 DAX: Администрирование 9 19.08.2008 14:53
gatesasbait: Installing Reporting Services, Analysis Services and Enterprise Portal for AX 2009 Blog bot DAX Blogs 0 03.07.2008 02:05
Client Axapta 3.0 SP4 и Linux. Как запустить? Daiver DAX: Администрирование 10 28.06.2007 15:59
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 19:52.
