Старый 10.03.2010, 01:05   #1
mscrmblog: Update Filename or List Item name programmatically in SharePoint/WSS
Источник: http://mscrmblog.net/2010/03/09/upda...harepoint-wss/
As simple as it sounds, it ain’t simple.
you would of thought the following would work:
SPFile file = web.GetFile(strUrl);file.name = "mynameFilename.txt";file.Update();does not compute..
There are 2 ways I’ve found of accomplishing this:
1. using the SPFile.MoveTo method:
string strUrl = "http://mysharepointsite/myolddocumentlibrary/Filename.txt";string newFileUrl = "http://mysharepointsite/mynewdocumentlibrary/mynewFilename.txt";SPSite site = new SPSite("http://mysharepointsite");SPWeb web = site.OpenWeb();web.AllowUnsafeUpdates = true; // this will stop it from erroring out due to security errorsSPFile file = web.GetFile(strUrl);file.MoveTo(newFileUrl);2. using File.Item["Name"] method..
string strUrl = "http://mysharepointsite/myolddocumentlibrary/Filename.txt";SPSite site = new SPSite("http://mysharepointsite");SPWeb web = site.OpenWeb();web.AllowUnsafeUpdates = true; // this will stop it from erroring out due to security errorsSPFile file = web.GetFile(strUrl);file.Item["Name"] = "NewFileName.txt";However i have found method 1 more reliable. hope this helps!
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
mscrmblog: Customize Marketing List (List Member View) Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Часовой пояс GMT +3, время: 03:22.
