Старый 25.05.2010, 23:05   #1
workflowax: Developing a business connector application
Источник: http://workflowax.wordpress.com/2010...r-application/
OK, so its slightly off my main blog topic, but I was quite interested to understand how the Workflow Website communicates with Dynamics AX through the .NET Business connector. So I decided to experiment and try build my own application using it. Much to my surprise it proved to be a quite easy and enjoyable experience with no major hiccups along the way (provided you have an AX client and Business Connector configuration already setup).
As an experiment I attempted to build a time tracker in C# to run on my desktop in order to actively keep track of the time that I work on my various client’s systems. It reads project information (activities, categories, projects etc..) from AX to populate the form. It then writes time data back to a table back in AX.
With relatively minimal effort I was able to accomplish exactly what I needed to. If you want to try your own hand at writing business connector applications, check out the MSDN walkthrough ovver here: http://msdn.microsoft.com/en-us/library/aa868997.aspx
Going through this exercise really helped me understand how the whole Dynamics AX 2009 Workflow framework functions. Well worth the time.
workflowax: Enabling Workflow Configurations for different modules Blog bot DAX Blogs 0 23.05.2010 08:06
workflowax: Dynamics AX WF Video: Building Business Process into your application Blog bot DAX Blogs 0 23.05.2010 08:06
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Часовой пояс GMT +3, время: 08:29.
