Старый 26.05.2010, 12:05   #1
mbsturk: Service msftesql was not found on computer 'XYZ'
Источник: http://mbsturk.blogspot.com/2010/05/...-found-on.html
CRM 4.0 Installing on Server 2008
ERROR:
Service msftesql was not found on computer 'XYZ'.
The specified service does not exist as an installed service.
CAUSE:
This error come from confilict between installing Microsoft Dynamics CRM 4.0 (Enterprise or Professional) with SQL 2008.
The msftesql is the "Microsoft SQL Server Full Text Indexing Service" which has a different name under SQL Server 2008.
SOLUTION:
- Run > Regedit
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services
- Rename MSSQLFDLauncher Folder to msftesql
- Reboot System
- Administrative Tools > Services > SQL Full-text Filter Daemon Launcher (MSSQLSERVER) and Check START Status
- Rename back msftesql Folder to MSSQLFDLauncher
- Take Enjoy
Service msftesql was not found on computer Nazarov Dynamics CRM: Администрирование 5 01.02.2011 09:36
Вылетает аxапта 4.0 при завершении работы Delfins DAX: Прочие вопросы 5 27.06.2007 15:43
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 20:38.
