Старый 02.07.2010, 18:05   #1
axaptapedia: Moving Table between layers
Источник: http://www.axaptapedia.com/Moving_Table_between_layers
Summary: Moving table between layers and not losing data due to changed element ids
... And keep the data !
I do realize that there is already an article on this topic that can be found here : [http://www.axaptapedia.com/Move_DB_o..._another_layer Move DB objects to another layer]
but I did'nt want to edit it and spoil the article.
Anyway, the article was a good beginning on how to do the moving of tables between layers, but there were a few things missing and it was not quite
working on Dynamics Ax 2009 for me. One of the problems for example are long table names. They get shortened in SQL server and the Id is used to
make the name unique so after moving the table, Dynamics Ax will look for the table with the old id in the name.
So I decided to build some kind of wizard for this.
[[Image:Wizard_PostResults.jpg]]
The whole explanation about how it works and what it does kan be found here
[http://www.ksaelen.be/wordpress/2010...etween-layers/ Axilicious : Moving objects between layers]
Downloading the sources :
[http://www.ksaelen.be/DynamicsAxXpo/...eLayerMove.xpo download xpo]
axaptapedia: Table Methods Generator Blog bot DAX Blogs 0 13.02.2009 02:05
axaptapedia: Go To Main Table Blog bot DAX Blogs 0 15.08.2007 19:40
axaptapedia: Export a table to Excel Blog bot DAX Blogs 0 27.04.2007 11:10
axaptapedia: Export a table to Excel Blog bot DAX Blogs 0 12.04.2007 16:10
axaptapedia: Change table owner Blog bot DAX Blogs 0 12.03.2007 17:30
Часовой пояс GMT +3, время: 17:47.
