Старый 14.07.2010, 07:07   #1
mscrmblog: Setup failed to determine whether a supported version of Microsoft Outlook is installed - Outlook 2010
Источник: http://mscrmblog.net/2010/07/13/setu...-outlook-2010/
I recently tried to install the CRM client with my install of office 2010 (on Windows 7) and got an error and couldn’t continue.
“Setup failed to determine whether a supported version of Microsoft Outlook is installed”
The Fix:
Right click the install window on the taskbar and click “Close Window” - It will give you a choice “Do you really want to cancel the setup” then click “Yes”
It should begin installing:
It should complete, now open outlook and configure CRM for outlook (CRM URL, Organisation etc..)
Install Client Update Rollup 7 and 11 or else the CRM toolbar will be in a new “Tab” in Outlook 2010 called “Addins”:
It should turn out like this:
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Microsoft Dynamics CRM Team Blog: Troubleshooting the Microsoft Dynamics CRM Client for Outlook Blog bot Dynamics CRM: Blogs 0 30.05.2009 12:05
axaptabuilder: Notes about my experience in setup of Microsoft Dynamics AX 4.0 integrated with Microsoft Visual Source Safe. Blog bot DAX Blogs 0 27.06.2007 09:30
axaptabuilder: Notes about my experience in setup of Microsoft Dynamics AX 4.0 integrated with Microsoft Visual Source Safe. Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 12:15.
