Старый 22.07.2010, 19:06   #1
Dynamics AX Sustained Engineering: Unexpected voucher number proposed when creating a new journal line after sorting the grid in a journal
Источник: http://blogs.technet.com/b/dynamicsa...a-journal.aspx
Scenario:
When creating a new line in a journal after sorting the data in the grid users may see an unexpected voucher number proposed for the new line.
Resolution:
To resolve the issue 3 objects require a change (note that the affected journal will determine the Form that requires the change).
1. \Forms\LedgerJournalTransVendInvoice\Methods\ClassDeclaration
Before:
SOURCE #ClassDeclaration
class FormRun extends ObjectRun
QueryBuildRange ledgerJournalTransRange;
LedgerJournalEngine ledgerJournalEngine;
After:
RecId currentRecordForCreate;
2. \Forms\LedgerJournalTransVendInvoice\Data Sources\LedgerJournalTrans\Methods\create()
Before:
try
ledgerJournalTransEntityManager.getFormDataEventManager().beginEntityCreateEvent();
journalFormTrans.datasourceCreatePre();
After:
try
if (currentRecordForCreate != 0)
ledgerJournalTrans_ds.findRecord(LedgerJournalTrans::findRecId(currentRecordForCreate, false));
3. \Forms\LedgerJournalTransVendInvoice\Methods\task()
New Method:
public int task(int _taskId)
int ret;
if (_taskId == 260)
currentRecordForCreate = ledgerJournalTrans.RecId;
ret = super(_taskId);
return ret;
Dynamics AX Sustained Engineering: One voucher number only and Transaction Date in Journals Blog bot DAX Blogs 0 27.05.2010 23:05
Dynamics AX Sustained Engineering: One voucher number only and Transaction Date in Journals Blog bot DAX Blogs 0 22.05.2010 04:11
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Часовой пояс GMT +3, время: 07:53.
